C2G 1m Mini DisplayPort Cable M/M - White
Quicklinx: 9MSCWS00 Mfr#: 84410
Select:
  • 1m
This cable is an ideal solution for connecting the Mini DisplayPort output of a small laptop or tablet to a computer monitor which accepts a Mini DisplayPort input. This cable carries a digital audio/video signal. Support of a High Bit Rate (HBR) bandwidth means that this cable can carry up to a 4k resolution. Built to DisplayPort 1.2 standards, this cable meets the requirements of high performance applications.
  • High compatibility
    Designed to connect seamlessly with PCs, this 1 m Mini DisplayPort Cable ensures a reliable connection between your computer and display devices.
  • Quality
    Compliant with DisplayPort 1.2 standards, this cable supports 4K UHD video for visual clarity and an immersive viewing experience.
  • Durable design
    Featuring male connectors on both ends, this white DisplayPort cable is built for longevity and consistent performance, making it a reliable choice for daily use.
C2G 1m Mini DisplayPort Cable 4K UHD M/M - White - DisplayPort cable - 1 m
DisplayPort cable
Length
1 m
Connector
Mini DisplayPort - male
Connector (Second End)
White
DisplayPort cable
Length
1 m
White
Connector
DisplayPort 1.2
