Replace your overused or misplaced power cable, or just get some extra cords for convenience. This power cord is designed to work with laptops that use a 3-slot power cord. Plus this heavy duty 18 AWG cord features a fully moulded design for maximum durability and long life. The female connector, often called a Clover Leaf connector, plugs directly into the device while the male connector plugs into a standard outlet.
Product Use
European replacement power cord for many laptops -
Warranty Details
This product carries a lifetime warranty -
Connector Information
The female connector is often called a Clover Leaf connector
- C2G Laptop Power Cord - power cable - IEC 60320 C5 to power CEE 7/7 - 1 m
- Power cable
- Molded
- Length
- 1 m
- Localisation
- Europe
- Connector
- Power IEC 60320 C5
- Connector (Second End)
- Power CEE 7/7 - male
- Rated Voltage
- AC 250 V
- Black
- Limited lifetime warranty
- Power cable
- American Wire Gauge (AWG)
- 18
- Rated Voltage
- AC 250 V
- Molded
- Length
- 1 m
- Black
- Localisation
- Europe
- Connector
