This precision-engineered cable is fully compliant with the DVI standard defined by DDWG (Digital Display Working Group). The DVI-I single link configuration provides enough bandwidth for resolutions up to 2048 x 1536 pixels and allows high speed transmission up to 9.9 Gbps. Three analogue 30 AWG coaxial lines enable high speed analogue transmission.
 - C2G DVI cable - 1 m
 - DVI cable - dual link
- Technology
 - Triple shielded
 - Colour-coded connectors
- Length
 - 1 m
- Connector
 - DVI-D - male
- Connector (Second End)
 - DVI-D - male
 - PC 99, RoHS
 - DVI cable
- Technology
 - Triple shielded
- Shielding Material
 - Foil with braid
- American Wire Gauge (AWG)
 - 28
- TMDS Links
 - Dual link
- Plated Connector
 - Gold
- Length
 - 1 m
- Connector
 - 24+1 pin digital DVI - male
 - PC 99, RoHS
