C2G 1m DisplayPort Male to Single Link DVI-D Male Adapter Cable
Quicklinx: 9MRQWS00 Mfr#: 84328
Length: 1m
Select:
£24.91 ex VAT
£29.89 inc VAT
This adapter cable is an ideal solution for connecting the DisplayPort output of a laptop to a computer monitor which accepts a DVI-D input. This cable carries a digital video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
  • Seamless connectivity
    Designed for optimal performance, the 1m DisplayPort to Single Link DVI-D Adapter Cable M/M facilitates a smooth and seamless connection between your DisplayPort-equipped PC and DVI-enabled monitor. This ensures high-quality video transmission without interference or quality loss.
  • Durable design
    Crafted with durability in mind, the cable features robust male connectors on both ends, including a 20 pin DisplayPort and an 18+1 pin digital DVI (Single-Link), ensuring a secure and stable connection that stands up to regular use without compromising signal integrity.
C2G 1m DisplayPort to Single Link DVI-D Adapter Cable M/M - DP to DVI - Black - DisplayPort cable - 1 m
DisplayPort cable - single link
Length
1 m
Connector
DisplayPort - male
Connector (Second End)
DVI-D - male
DisplayPort cable
TMDS Links
Single link
Length
1 m
Connector
20 pin DisplayPort - male
18+1 pin digital DVI (Single-Link) - male
Length: 1m
Brand: C2G
