C2G 1m DisplayPort Cable with Latches M/M - Black
Quicklinx: 9MS3WS00 Mfr#: 84400
This cable is an ideal solution for connecting the DisplayPort output of a laptop to a computer monitor which accepts a DisplayPort input. This cable carries a digital audio/video signal and the connectors feature latches which secure the cable in the port. Support of a High Bit Rate (HBR) bandwidth means that this cable can carry up to a 4k resolution. Built to DisplayPort standards, this cable meets the requirements of high performance applications.
C2G 1m DisplayPort Cable with Latches 8K UHD M/M - 4K - Black - DisplayPort cable - 1 m
DisplayPort cable
Double shielded
Latched
Length
1 m
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - male
DisplayPort cable
Double shielded
Shielding Material
Aluminium foil with braid
American Wire Gauge (AWG)
32
Latched
Length
1 m
Connector
20 pin DisplayPort - male
DisplayPort 1.2
