C2G 1m DisplayPort™ 1.1 Male to DVI-D™ Male Cable
Quicklinx: 8021WS00 Mfr#: 81290
Use this DisplayPort to DVI cable to connect a DisplayPort source directly to a DVI monitor or display. The passive design will support a 1920 x 1080 resolution up to 3 metres. It is VESA-compliant with transparent operation which will auto-calibrate and configure the signal for minimal configuration. Great for applications when you want to connect a newer laptop or desktop to a DVI-enabled display.
C2G DisplayPort 1.1 to DVI-D Cable - DisplayPort cable - 1 m
DisplayPort cable - dual link
Shielded
Molded, thumbscrews
Length
1 m
Connector
DisplayPort - male
Connector (Second End)
DVI-D - male
DisplayPort cable
Shielded
Shielding Material
Foil
American Wire Gauge (AWG)
28
TMDS Links
Dual link
Plated Connector
Nickel
Molded, thumbscrews
Length
1 m
Connector
20 pin DisplayPort - male
24+1 pin digital DVI - male
DisplayPort 1.1
