C2G 1m DB37 M/F Extension Cable
Quicklinx: 682QWS00 Mfr#: 81405
Use DB37 extension cables from C2G for your connection to back up important files from your CPU on a regular basis. Use these cables with your tape back-up or Bernoulli Box applications for reliable data storage and retrieval. The line of extension and replacement cables is fully shielded against EMI/RFI interference, giving you the assurance of quality transmissions every time.
C2G Extension Cable - serial extension cable - DB-37 to DB-37 - 1 m
Serial extension cable
Shielded
Length
1 m
Connector
37 pin D-Sub (DB-37) - male
Connector (Second End)
37 pin D-Sub (DB-37) - female
Shielded
Length
1 m
Connector
RoHS
