C2G 1m DB25 Male to Centronics 36 Male Parallel Printer Cable
Quicklinx: 63P4WS00 Mfr#: 81478
Parallel printer cables from C2G ensure a reliable connection between your PC and uni-directional printer. Parallel printer cables are ideal for dot-matrix and older laser printers. Don't be fooled by cheaply assembled look-alike cables - these cables are durable enough for use in industrial settings.
  • Robust connectivity
    Experience seamless and reliable connectivity with the C2G printer cable, featuring a male 25 pin D-Sub (DB-25) connector on one end and a male 36 pin Centronics connector on the other. This design ensures a stable connection between your PC and printer, enhancing your productivity.
  • Enhanced durability
    Constructed with a foil shielding material, the C2G printer cable is designed to withstand interference, ensuring high-quality data transmission without loss or corruption. Its shielded technology guards against external noise, making it ideal for busy office environments.
C2G printer cable - 1 m
Printer cable
Shielded
Molded, thumbscrews
Length
1 m
Connector
DB-25 - male
Connector (Second End)
36 PIN Centronics - male
RoHS
Printer cable
Shielded
Shielding Material
Foil
Molded, thumbscrews
Length
1 m
Connector
25 pin D-Sub (DB-25) - male
RoHS
