C2G 1m Cat6a Shielded Patch - Grey
Quicklinx: 8GZXWS00 Mfr#: 89901
Length: 1m
Colour: Grey
£3.96 ex VAT
£4.75 inc VAT
This Booted Shielded Cat6a patch cable is ideal for use with 10GBase-T ports and equipment, such as network adapters, hubs, switches, routers, DSL/cable modems and patch panels, and will protect a high speed 10 Gigabit network connection from noise and electromagnetic interference. For voice/data/video distribution, this cable will handle bandwidth-intensive applications and drastically reduces both impedance and structural return loss (SRL). Each patch cable is fully tested to meet ANSI/TIA 568 C.2 Cat6a component requirements. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality cable and plugs, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded a network installation. Each cable is individually labelled with the length for ease of use.
  • High-speed connectivity
    Experience fast data transfer speeds with the Cat6a Booted Shielded (STP) Network Patch Cable, tested up to 600 MHz to meet the demands of high-speed data applications.
  • Enhanced reliability
    The shielded twisted pair (STP) technology and RoHS compliance ensure minimal noise and interference, providing a reliable and secure connection for your networking needs.
  • Universal compatibility
    Designed to connect seamlessly with any PC, this patch cable features male RJ-45 connectors on both ends, making it a versatile choice for a wide range of network configurations.
C2G Cat6a Booted Shielded (STP) Network Patch Cable - patch cable - 1 m - grey
Patch cable - CAT 6a
Shielded twisted pair (STP)
Wires per Cable
8 wires
Molded, snagless, stranded
Length
1 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Length
1 m
Grey
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 600 MHz
Length: 1m
Colour: Grey
Brand: C2G
