Cables To Go's Cat6 crossover cables are perfect for distributing data, voice, video and connecting network switches and hubs without an uplink port to other switches and hubs. These 550MHz rated patch cables ensure that you always have the necessary throughput to handle bandwidth-intensive applications. Note:These cables are for 10100 ethernet only and will not work for gigabit ethernet as only two pairs of this cable are crossed.
Our new moulded, snag-free "clip" prevents unwanted cable snags during installation and doesn't impair the ability to insert and remove the connector from the port. It also provides extraordinary strain-relief, so that the cable is not damaged even when pulled excessively.
Enhanced connectivity
The Cat6 Booted Unshielded (UTP) Crossover Patch Cable by C2G is designed to facilitate efficient data transfer and communication between PCs. With its RJ-45 male connectors on both ends, this cable ensures a secure and reliable connection for networking needs. -
High-quality performance
Featuring a tested frequency of up to 550 MHz and constructed with 24 American Wire Gauge (AWG) PVC jacket material, this crossover cable is built for durability and efficient data transmission. The gold-plated connectors not only provide a robust connection but also resist corrosion, ensuring longevity and maintaining signal integrity. -
Universal compatibility
Adhering to the T568B wiring scheme and meeting RoHS compliant standards, this cable is compatible with PCs, making it a versatile solution for various networking setups.
- C2G Cat6 Booted Unshielded (UTP) Crossover Patch Cable - crossover cable - 1 m - black
- Crossover cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Molded, snagless, stranded
- Length
- 1 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Black
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Plated Connector
- Gold
- Length
- 1 m
- Black
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 550 MHz
