C2G 1m Cat5E UTP LSZH Network Patch Cable - Green
Quicklinx: CMFYWS00 Mfr#: 82424
For fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels with a LSZH outer jacket. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily colour-code your network installation. Each cable is individually labelled with the length for ease of use.
Connector 1: (1) RJ-45 Male.
Connector 2: (1) RJ-45 Male.
  • Enhanced durability
    Featuring a Low Smoke Zero Halogen (LSZH) jacket, this patch cable is designed for environments where PVC's toxic properties are a concern, offering a safer alternative for cabling.
  • Superior connectivity
    Gold-plated connectors ensure a clean and clear transmission by preventing corrosion, maintaining a high-quality connection that resists degradation over time.
  • Advanced performance
    With minimized Near-End Crosstalk (NEXT) and reduced structural return loss (SRL), this cable is engineered to deliver superior signal integrity, enhancing your network's overall performance.
C2G patch cable - 1 m - green
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wires per Cable
8 wires
Booted, snagless, minimised Near-End Crosstalk (NEXT), reduced structural return loss (SRL), latching clip
Length
1 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Green
Network Cable Type
Jacket Material
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
1 m
39 g
Green
Connector
RJ-45 - male
RJ-45 - male
RoHS, TIA/EIA-568-B.2
