C2G 1m Cat5E 350 MHz Snagless Patch Cable - Black
Quicklinx: 6BM1WS00 Mfr#: 83181
Length: 1m
Colour: Black
£2.68 ex VAT
£3.21 inc VAT
For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
  • High-quality connectivity
    The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G is designed with a high-quality PVC jacket and gold-plated connectors to ensure reliable connectivity and durability. Its American Wire Gauge (AWG) of 24 and the use of T568B wiring scheme enhance signal clarity and reduce interference, making it an ideal choice for high-speed network applications.
  • Enhanced performance
    Tested to support frequencies up to 350 MHz, this patch cable is engineered to exceed the performance requirements of CAT 5e, ensuring high-speed data transmission for PC compatibility. The use of unshielded twisted pair (UTP) technology minimizes noise and crosstalk, providing a stable and secure connection for all your networking needs.
  • Universal compatibility
    Featuring RJ-45 male connectors on both ends, the cable is designed for easy and secure connection between devices. Its universal design is compatible with a wide range of devices, making it a versatile solution for various networking environments.
C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 1 m - black
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded
Length
1 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
1 m
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
Length: 1m
Colour: Black
Brand: C2G
