With a C2G Enhanced Cat5 350MHz Crossover Patch Cable and a network adapter, you can easily network two Windows-based computers in a peer-to-peer networking configuration. In addition, this cable can be used for hub-to-hub, transceiver-to-transceiver or repeater-to-repeater Ethernet connections.
High-quality connectivity
The Cat5e Non-Booted Unshielded (UTP) Network Crossover Patch Cable is designed with 24 AWG American Wire Gauge for reliable signal transmission. Its gold-plated connectors ensure a clear, uninterrupted connection, making it ideal for various networking setups. -
Durable design
Featuring a PVC jacket material, this crossover cable is built to withstand rigorous use in any environment. The durable construction ensures long-lasting performance, providing value and reliability. -
Versatile performance
Tested for frequencies up to 350 MHz, this cable supports a wide range of applications from home networking to high-speed data transfer tasks in office settings. Its T568B wiring scheme and UTP technology facilitate error-free data transmission.
- C2G Cat5e Non-Booted Unshielded (UTP) Network Crossover Patch Cable - crossover cable - 1 m - black
- Crossover cable - CAT 5e
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Stranded, uniboot
- Length
- 1 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Black
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Stranded, uniboot
- Length
- 1 m
- Black
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 350 MHz
