For voice/data/video distribution, this cable will handle bandwidth-intensive applications. Meets all Cat5E TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL).
Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
Constructed from high-quality cable and a shortened body plug, this design minimizes Near-End Crosstalk (NEXT) levels.
High-quality connectivity
The Cat5e Non-Booted Unshielded (UTP) Network Patch Cable by C2G ensures a reliable connection with its high-performance American Wire Gauge (AWG) 24 wiring and gold-plated connectors. Designed for durability and consistent signal integrity, this cable is ideal for various networking environments. -
Enhanced performance
Tested for frequencies up to 350 MHz, this patch cable meets the Category 5e standard, supporting fast and efficient data transfer rates. Its T568B wiring scheme and UTP technology minimize interference, providing a stable and secure network connection. -
Versatile compatibility
Featuring RJ-45 male connectors on both ends, the cable is compatible with a wide range of devices, including PCs. Its PVC jacket material ensures flexibility and protection against physical strain, making it suitable for both home and office settings.
- C2G Cat5e Non-Booted Unshielded (UTP) Network Patch Cable - patch cable - 1 m - white
- Patch cable - CAT 5e
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Stranded, uniboot
- Length
- 1 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- White
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Stranded, uniboot
- Length
- 1 m
- White
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 350 MHz
