The 3.5mm stereo audio cable is specifically designed for quality computer audio applications. It attaches a PC sound card, portable CD player or any mini-stereo audio device with 3.5mm jacks to a multimedia speaker. This cable features two copper conductors and a drain wire. The conductors and drain wire are wrapped with a braided shield which prevents unwanted EMI/RFI interference. Fully snagless nickel-plated connectors provide excellent strain relief for durable use.
- C2G audio cable - 1 m
- Cable
- Audio cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 29
- Length
- 1 m
- Connector
- Mini-phone stereo 3.5 mm - male
- Connector (Second End)
- Stranded conductor, moulded
- Cable Type
- Audio cable
- Technology
- Shielded
- 29
- Shielding Material
- Foil
- Length
- 1 m
- Plated Connector
- Nickel
- Connector
- RoHS
