One end of this power cord will work with most desktop PCs, monitors, scanners, printers and other devices that use the 3-pin shroud power connector; the other end features a 2-prong Schuko European plug. The female connector plugs directly into device, while the male connector plugs into the standard European outlet. This premium, heavy-duty, 16 AWG cord features a fully moulded design for maximum durability and long life.
Versatile compatibility
Designed to power a wide range of PCs, this universal power cord is the perfect solution for a variety of desktop computing needs, ensuring your setup is always energized and operational. -
Robust construction
Featuring a 16 AWG cable, this power cord is built for durability and reliable performance, providing a secure and stable power connection for your computing equipment.
- C2G Universal Power Cord - power cable - power CEE 7/7 to power IEC 60320 C13 - 1 m
- Power cable
- Molded
- Length
- 1 m
- Localisation
- Europe
- Connector
- Power CEE 7/7 - male
- Connector (Second End)
- Power IEC 60320 C13
- Black
- Limited lifetime warranty
- Power cable
- American Wire Gauge (AWG)
- 16
- Molded
- Length
- 1 m
- Black
- Localisation
- Europe
- Connector
