The Mini DisplayPort to HD adapter cable is an ideal solution for a conference room or huddle space by connecting a tablet, laptop computer, or another source device with a Mini DisplayPort output to a projector, monitor, or HDTV which accepts an HDMI input. [B] Convenience [/B] This adapter cable carries a digital audio/video signal for a convenient, single cable solution that delivers audio and video to a presentation. [B] Performance [/B] Supporting resolutions up to 1080p at 60Hz with a simple plug and play allows this adapter cable to meet the requirements for high performance applications. Note: This product is TAA compliant.
Robust construction
Crafted with a PVC jacket and aluminum mylar foil with braid, this adapter cable ensures durability and reliable performance, protecting against external interference. -
Versatile connectivity
Featuring a Mini DisplayPort male connector on one end and a 19-pin HDMI Type-A male connector on the other, this cable offers seamless connectivity between your Mini DisplayPort-equipped device and an HDMI display.
- C2G 3ft Mini DisplayPort to HDMI Adapter Cable - Mini DP Male to HDMI Female - Black - video adapter cable - Mini DisplayPort to HDMI - TAA Compliant - 1 m
- Video adapter cable
- Technology
- Shielded
- Length
- 1 m
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- 19 pin HDMI Type A - male
- Black
- TAA Compliant
- 3-year warranty
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- PVC
- Length
- 1 m
- Black
- Connector
- TAA Compliant
- 3-year warranty
