C2G 15m Premium Shielded HD15 SXGA M/M Monitor Cable with 90° Down Angled Male Connector
Quicklinx: 67Z4WS00 Mfr#: 81069
Gain maximum flexibility in positioning your monitor with this angled connector cable. The right-angled connector allows installation in even the tightest locations; the cable breaks down from this connector. This premium VGA extension cable is ideal for video presentation devices, video splitters, and KVM switches. Constructed from premium grade video cable, it uses a combination of coax and twisted pair to accommodate cable runs up to 30 meters away without a booster (in most cases), and without the typical distortion problems associated with extended length cabling runs.
  • Enhanced connectivity
    The C2G Premium SXGA 90° Down Angled VGA cable offers a unique solution for tight spaces, featuring a down-angled connector that allows for connection in hard-to-reach areas, ensuring a seamless fit behind desks or in tight cabinet spaces.
  • High-quality construction
    Constructed with shielded twisted pair coaxial technology, this VGA cable ensures high-quality, interference-free signal transmission, making it ideal for high-resolution presentations and video streaming.
  • Universal compatibility
    Designed to be fully compatible with PCs, this VGA cable facilitates a reliable connection between your computer and monitors, projectors, or any other display device with a 15 pin HD D-Sub (HD-15) interface, enhancing your visual experience.
C2G Premium SXGA 90° Down Angled - VGA cable - 15 m
VGA cable
Shielded twisted pair coaxial
90° connector
Length
15 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
RoHS
VGA cable
90° connector
Length
15 m
Connector
RoHS
