Flexima UXGA cables from C2G deliver high performance and flexibility. These ultra thin cables are highly flexible to make installation in even the tightest areas simple. Unlike cheap VGA cables, the Flexima cables will not coil or snag during installation. Flexima UXGA cables are ideal for video presentations, home cinema and HDTV applications, classroom environments, POS and server rooms. Or simply organize your work area for maximum comfort and efficiency.
- C2G Flexima UXGA - VGA cable - 15 m
- VGA cable
- Technology
- Triple shielded coaxial
- Length
- 15 m
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- RoHS
- VGA cable
- Technology
- Length
- 15 m
- Connector
- 15 pin HD D-Sub (HD-15) - male
- RoHS
