C2G 15m Cat6 550 MHz Snagless Patch Cable - Blue
Quicklinx: 6BQ0WS00 Mfr#: 83393
For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
  • High-speed connectivity
    Experience fast data transfer speeds with the Cat6 Booted Unshielded (UTP) Network Patch Cable, tested up to 550 MHz. This ensures efficient and reliable performance for gaming, streaming, and high-speed networking.
  • Durable design
    Constructed with a 24 American Wire Gauge (AWG) and a robust PVC jacket material, this patch cable is designed for durability and long-lasting use. The gold-plated connectors also provide a secure connection and resist corrosion.
  • Universal compatibility
    Featuring RJ-45 male connectors on both ends, this network patch cable is compatible with a wide range of devices. Whether you're connecting PCs, servers, or network switches, setup is straightforward and hassle-free.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 15 m - blue
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Molded, snagless, stranded
Length
15 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Patch cable - CAT 6
Jacket Material
PVC
24
Plated Connector
Gold
Length
15 m
Blue
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
