Quickly secure your cable runs for your audio/video equipment stack, computer desk or networking closet. The high-strength nylon-binding strap is easy to use and reuse with its solid nylon buckle and self-attaching, hook-and-loop design.
- C2G Hook-and-Loop cable strap
- Product Type
- Cable strap
- Packaged Quantity
- 12 (specifications are for single item)
- 1.3 cm
- Length
- 15 cm
- Product Material
- Nylon
- Black
- RoHS
- Limited lifetime warranty
- Packaged Quantity
- Product Type
- Cable strap
- Product Material
- Nylon
- 1.3 cm
- Length
- 15 cm
- Enclosure Colour
- Black
- RoHS
- Limited warranty - lifetime
