The TruLink USB 2.0 Active Extension Cable is perfect when you need extra distance; this cable will extend the reach of your USB 2.0 cable or device 12m (40'). The USB active extension cable actively buffers the incoming and outgoing signals to ensure compliance with the USB 2.0 specification for electrical and timing minimums. Both low and high speed USB devices will function equally well with this cable. Great for extending the reach to your USB devices.
- C2G TruLink USB 2.0 Active Extension Cable - USB extension cable - 12 m
- Active cable (signal regeneration)
- Length
- 12 m
- Connector
- 4 pin USB Type A - female
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- 1 year warranty
- Length
- 12 m
- Connector
- USB / USB 2.0, Plug and Play, RoHS
- 1 year warranty
