C2G 10m Select High Speed HDMI with Ethernet
Quicklinx: 915NWS00 Mfr#: 80557
Type: HDMI
Length: 10m
£30.17 ex VAT
£36.20 inc VAT
The Select Standard Speed HDMI Cable provides a reliable connection up to a distance of 30 feet (10 metres) for home theatre, desktop and commercial audio video applications requiring standard speed HDMI capabilities and video resolutions up to 1080i. The CL2 rated cable jacket is designed to meet the requirements for in-wall installations. The Ethernet capabilities of the cable enable users to connect multiple Ethernet-enabled devices through a single Ethernet connection. This fully-functional cable is tested to perform at industry standards and backed by a lifetime warranty.
  • High-quality connectivity
    The 10 m Select Standard Speed HDMI Cable with Ethernet by C2G offers a high-quality connection between your HDMI devices. With its gold-plated connectors and shielded aluminum foil with braid, it ensures a reliable and clear signal transmission, minimizing interference and signal loss.
  • Durable design
    Designed with durability in mind, this HDMI cable features a PVC jacket and an American Wire Gauge (AWG) of 28, providing a robust and flexible solution for your home or office setup. Its impedance is optimized at 100 ohm to maintain signal integrity over longer distances.
  • Versatile compatibility
    Equipped with male 19-pin HDMI Type-A connectors on both ends, this cable is compatible with a wide range of devices that support HDMI. It simplifies the connection process, allowing for the seamless integration of your devices with Ethernet support for network connectivity.
C2G 10m Select Standard Speed HDMI Cable with Ethernet - HDMI cable with Ethernet - 10 m
Cable
Shielded
28
Length
10 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
Cable Type
Shielded
28
Jacket Material
PVC
Shielding Material
Aluminium foil with braid
Impedance
100 Ohm
Length
10 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
UL
Limited warranty - lifetime
Type: HDMI
Length: 10m
Brand: C2G
