C2G 10m SC-SC 9/125 OS1 Duplex Singlemode PVC Fibre Optic Cable (LSZH) - Yellow
Quicklinx: 9CC3WS00 Mfr#: 85573
Cost-effective solution that provides high bandwidth and transmission rates over longer distances. With SC to SC termination, this high quality fibre optic patch cable is specifically designed for Gigabit Ethernet applications. The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures. This reduces the amount of harmful toxic and corrosive gases that cabling made with plastic materials would otherwise emit into the air during combustion. This construction makes LSZH cables ideal for use where the protection of people and equipment from harmful corrosive gases is absolutely critical. The patented injection moulding process provides each connection greater durability in resisting pulls, strains and impacts from cabling installs. Each cable is 100% optically inspected and tested for insertion loss before you receive it. A pull-proof jacket design surrounds the popular 9/125 Single-mode fibre, immune to electrical interference.
  • High-quality connectivity
    The SC-SC 9/125 OS1 Duplex Singlemode PVC Fiber Optic Cable is designed with a core and cladding diameter of 9 / 125 micron, ensuring reliable connectivity for critical network applications. Its duplex configuration allows for bidirectional data transmission, enhancing the efficiency of communication systems.
  • Durable and safe
    Featuring a Low Smoke Zero Halogen (LSZH) jacket, this fiber optic cable minimizes the amount of toxic and corrosive gas emitted during combustion. This makes it safer for the environment and ideal for use in poorly ventilated areas, ensuring both durability and user safety.
  • Optimized for performance
    Compliant with OS1 standards, the cable is suitable for long-distance, high-bandwidth data transmission. It supports a wide range of temperatures from -20°C to 70°C, making it suitable for various operating environments without compromising performance.
C2G SC-SC 9/125 OS1 Duplex Singlemode PVC Fiber Optic Cable (LSZH) - patch cable - 10 m - yellow
Patch cable - OS1
Duplex fibre optic
Type of Fibre Optics
Singlemode
Halogen-free
Length
10 m
Core / Cladding Diameter
9 / 125 micron
Connector
2 x SC single-mode - male
Connector (Second End)
Yellow
Network Cable Type
Patch cable - OS1
Duplex fibre optic
Singlemode
Jacket Material
Fibre Qty
2
9 / 125 micron
Halogen-free
Length
10 m
Yellow
Connector
TIA/EIA-455-171A
-20 °C
70 °C
