C2G 10m RJ11 6P4C Straight Modular Cable
Quicklinx: 801BWS00 Mfr#: 83867
For RS-232 modular adapters for dumb terminal hookups and other serial/parallel extension applications. Constructed from 28 AWG silver satin wire, this straight through-pinned cable is ideal for cost-saving voice and data applications not requiring high data rates.
  • Reliable connectivity
    The RJ11 6P4C Straight Modular Cable by C2G ensures a dependable connection between your PC and network devices. With male RJ-11 connectors on both ends, this phone cable is designed for straightforward, efficient connectivity.
  • High-quality construction
    Featuring an American Wire Gauge (AWG) of 28 and constructed with 4 wires per cable, this product promises durability and a high-quality signal transmission for your networking needs.
C2G RJ11 6P4C Straight Modular Cable - phone cable - 10 m - grey
Phone cable
Wires per Cable
4 wires
Length
10 m
Connector
RJ-11 - male
Connector (Second End)
RJ-11 - male
Grey
Network Cable Type
Phone cable
28
Wires per Cable
4 wires
Length
10 m
Grey
Connector
RJ-11 - male
RJ-11 - male
