C2G 10M RAPIDRUN DIGITAL RUNNER HT CL2
Quicklinx: 63RJWS00 Mfr#: 87504
Imagine a DVI cable you can pull through 30 mm conduit with no soldering of the DVI connector! Or having the option of switching the installed cable from DVI to HDMI in less than a minute! With RapidRun, you can easily do this and more. No cabling solution on the market will do more to make your installations easier or more versatile!
RapidRun's revolutionary design provides the greatest flexibility and ease of installation without loss of signal quality. Three styles of Runner base cables, 3-coax with 4 twisted-pairs, 5-coax and HDMI/DVI, allow this unique cable system to be configured for UXGA, component video, composite video, digital/analog audio and/or digital audio/video signals.
The key to this RapidRun is the proprietary connector design which features a locking mechanism that connects to a Break-Away flying lead. The amazing RapidRun connector also enables you to pull the Runner base cable through 30 mm conduit and terminate with a flying lead.
C2G RapidRun Digital Runner - video / audio cable - 10 m
Cable
Video / audio cable
Shielded twisted pair (STP)
American Wire Gauge (AWG)
24
Length
10 m
Connector
MUVI connector
Connector (Second End)
MUVI connector
Class 2 rated
Cable Type
Video / audio cable
24
Shielding Material
Aluminum mylar foil with tinned copper braid
Length
10 m
Class 2 rated
Connector
MUVI connector
MUVI connector
RoHS
