Go the distance without ghosting and signal distortion. Constructed from premium grade composite coaxial and twisted pair shielded cables, this ultra-premium monitor cable ensures crisp, distortion-free video so you have maximum monitor positioning flexibility. Uses three internal coax lines for red, green and blue. Ferrited to protect against EMI/RFI interference, this double-shielded cable consists of 125% foil shielding and 90% tinned copper braid shielding.
- C2G Pro Series UXGA - VGA extension cable - 10 m
- Technology
- Double shielded coaxial
- Length
- 10 m
- Connector
- HD-15 - male
- Connector (Second End)
- HD-15 - female
- RoHS
- Technology
- Shielding Material
- Foil with tinned copper braid
- Length
- 10 m
- Connector
- 15 pin HD D-Sub (HD-15) - male
- 15 pin HD D-Sub (HD-15) - female
- RoHS
