C2G 10m Premium Shielded HD15 SXGA M/M Monitor Cable with 90° Up Angled Male Connector
Quicklinx: 67YLWS00 Mfr#: 81046
Premium Shielded SXGA cables with Angled Connectors from C2G allow installation in even the tightest places. You can turn the connector to best fit the placement of a video device. These premium VGA cables are ideal for video presentation devices, video splitters and KVM switches. Constructed from premium grade video cable, these cables use a combination of coax and twisted-pair to accommodate cable runs up to 30.48 meters away, with none of the typical distortion problems associated with extended length cabling runs.
  • Enhanced connectivity
    The C2G Premium SXGA 90° Up Angled VGA cable offers a unique solution for tight spaces, featuring a 90° up-angled connector that allows for easy installation in confined areas. This design ensures a secure connection while minimizing strain on the cable, making it ideal for setups with limited space.
  • High quality
    Constructed with shielded twisted pair coaxial technology, this VGA cable ensures high-quality, interference-free signal transmission. Its robust design is tailored to maintain signal integrity over distances, providing clear and reliable video quality for your PC.
  • Universal compatibility
    Designed to be fully compatible with PCs, this VGA cable facilitates a seamless connection between your computer and monitors or projectors. The male to male 15 pin HD D-Sub connectors offer a straightforward setup, ensuring a hassle-free user experience.
C2G Premium SXGA 90° Up Angled - VGA cable - 10 m
VGA cable
Shielded twisted pair coaxial
90° connector
Length
10 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
RoHS
VGA cable
90° connector
Length
10 m
Connector
RoHS
