C2G 10m IEEE-1284 DB25 Male to Centronics 36 Male Parallel Printer Cable
Quicklinx: 684DWS00 Mfr#: 81463
High-speed IEEE-1284 compliant cables from C2G ensure you realize the added speed and two way communications offered by your newer inkjet, laser, or all-in one printers and scanners. This advanced technology, which defines high-speed, bi-directional communications between PC and peripheral, requires both high quality connectors and a specialized wire-type to handle the increased data rates.
C2G printer cable - 10 m
Printer cable
Double shielded twisted pair
Molded
Length
10 m
Connector
DB-25 - male
Connector (Second End)
36 PIN Centronics - male
RoHS
Printer cable
Shielding Material
Foil with braid
Molded
Length
10 m
Connector
25 pin D-Sub (DB-25) - male
IEEE-1284, RoHS
