C2G 10m HD15 UXGA + 3.5mm Audio M/M Monitor Cable
Quicklinx: 63SRWS00 Mfr#: 81032
The Pro Series UXGA monitor cable with 3.5mm audio from C2G is the ideal high performance solution for quickly connecting your PC to a video display system with speakers. Use this cable with projectors, flat-screen monitors, KVM switches with audio, speakers, or a microphone. Designed to support resolutions up to 1600 x 1200, this cable can support distances up to 30.48 meters without conditioning the signal. It is ideal for video presentations, projector applications and classroom environments.
C2G Pro Series UXGA - display / audio cable kit - 10 m
Display / audio cable kit
Shielded
Length
10 m
Connectors
HD-15 (VGA) - male , Mini-phone stereo 3.5 mm - male
Connectors (Second End)
RoHS
Shielded
Length
10 m
Connectors
15 pin HD D-Sub (HD-15) - male , Mini-phone stereo 3.5 mm - male
Cable Kit Details
1 x VGA gender changer - 15 pin HD D-Sub (female) to 15 pin HD D-Sub (female) , 1 x display / audio cable - 15 pin HD D-Sub (male), mini-phone stereo 3.5 mm (male) to 15 pin HD D-Sub (male), mini-phone stereo 3.5 mm (male) - 10 m
RoHS
