For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
Enhanced connectivity
The Cat6 Booted Unshielded (UTP) Network Patch Cable by C2G ensures a reliable connection with its high-quality, gold-plated RJ-45 connectors. These connectors provide a secure link between devices, minimizing interference and maximizing performance. -
Durable design
Featuring a robust PVC jacket and an American Wire Gauge (AWG) of 24, this patch cable is designed for durability and long-term use. Its construction is compliant with RoHS standards, ensuring both safety and quality. -
High-speed performance
With a tested frequency of up to 550 MHz, this network patch cable is capable of supporting high-speed data transmission. This makes it an ideal choice for various networking requirements, from home setups to more demanding office environments.
 - C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 10 m - red
 - Patch cable - CAT 6
- Technology
- Wiring Scheme
 - T568B
 - Molded, snagless, stranded
- Length
 - 10 m
- Connector
 - RJ-45 - male
- Connector (Second End)
 - RJ-45 - male
 - Red
- Network Cable Type
- Technology
- Wiring Scheme
 - T568B
- Jacket Material
 - PVC
- American Wire Gauge (AWG)
 - 24
- Plated Connector
 - Gold
- Length
 - 10 m
 - Red
- Connector
 - RJ-45 - male
 - RJ-45 - male
 - RoHS - up to 550 MHz
