C2G 10m Cat6 550 MHz Snagless Patch Cable - Pink
Quicklinx: 6BTCWS00 Mfr#: 83594
For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
  • High-speed connectivity
    Experience seamless network performance with the Cat6 Booted Unshielded (UTP) Network Patch Cable, designed to support frequencies up to 550 MHz. This high-quality cable ensures stable and fast connections for all your computing needs.
  • Durable design
    Constructed with a PVC jacket and 24 AWG American Wire Gauge, this patch cable is built for durability. The gold-plated connectors not only provide a reliable connection but also resist corrosion, ensuring long-lasting performance.
  • Universal compatibility
    Featuring RJ-45 male connectors on both ends and adhering to the T568B wiring scheme, this cable is compatible with a wide range of devices. Whether for home or office use, it seamlessly integrates with your existing network setup.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 10 m - pink
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
10 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Pink
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Plated Connector
Gold
Length
10 m
Pink
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
