For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
High-quality connectivity
The Cat6 Booted Unshielded (UTP) Network Patch Cable by C2G is designed with a 24 American Wire Gauge (AWG) and a durable PVC jacket, ensuring reliable connectivity and longevity. Its gold-plated RJ-45 connectors provide a high-quality connection that minimizes resistance and maximizes performance. -
Enhanced performance
With a tested frequency of up to 550 MHz, this patch cable supports high-speed data transfer rates, making it suitable for various networking applications. Whether for home or office use, it ensures efficient network performance and minimal signal interference. -
Universal compatibility
Designed to be compatible with PCs, this network patch cable features male RJ-45 connectors on both ends, making it versatile for connecting a wide range of devices. Its compliance with RoHS standards also ensures environmentally safe usage.
- C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 10 m - grey
- Patch cable - CAT 6
- Technology
- Molded, snagless, stranded
- Length
- 10 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Grey
- Network Cable Type
- Technology
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Plated Connector
- Gold
- Length
- 10 m
- Grey
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 550 MHz
