C2G 10m Cat5e Non-Booted Shielded (STP) Network Patch Cable - Red
Quicklinx: 9N3LWS00 Mfr#: 83800
Protect your high speed network from noise and electromagnetic interference when you connect with our shielded Cat5E patch cable. Meets or exceeds industry standards for NEXT and return loss. The snagless boot provides extra strain relief and durability. Available in a variety of Colours to easily colour-code your network installation.
  • Enhanced connectivity
    Equipped with gold-plated RJ-45 connectors, this Cat5e Booted Shielded (STP) Network Patch Cable ensures a reliable connection with enhanced conductivity and corrosion resistance for long-term performance.
  • Robust design
    The cable features a durable PVC jacket and minimized Near-End Crosstalk (NEXT), providing a stable and secure network connection by reducing interference.
  • Versatile compatibility
    Designed to support a T568B wiring scheme and compatible with PCs, this patch cable offers a versatile solution for a wide range of network environments.
C2G Cat5e Booted Shielded (STP) Network Patch Cable - patch cable - 10 m - red
Patch cable - CAT 5e
Shielded twisted pair (STP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, minimised Near-End Crosstalk (NEXT)
Length
10 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Red
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
10 m
Red
Connector
RJ-45 - male
RJ-45 - male
