C2G 10m Cat5E 350 MHz Snagless Booted Patch Cable - Grey
Quicklinx: 69N9WS00 Mfr#: 83147
Length: 10m
Colour: Grey
£7.53 ex VAT
£9.03 inc VAT
For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
  • High-quality connectivity
    The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G is designed with a 24 American Wire Gauge (AWG) and gold-plated connectors, ensuring reliable, high-speed data transmission up to 350 MHz. Its PVC jacket material and T568B wiring scheme provide durability and optimal performance for networking requirements.
  • Versatile compatibility
    Featuring RJ-45 male connectors on both ends, this patch cable is compatible with a wide range of devices, making it a versatile choice for connecting PCs and other network components in a variety of settings.
C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 10 m - grey
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded
Length
10 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
10 m
Grey
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
Length: 10m
Colour: Grey
Brand: C2G
