C2G 10m Cat5E 350 MHz Assembled Patch Cable - Grey
Quicklinx: 69PZWS00 Mfr#: 83007
Perfect for your home office or a large installation project, Enhanced Cat5E 350MHz Assembled Patch Cables from C2G distribute data, voice and video over today's advanced fast Ethernet and gigabit computer networks. These cables will handle bandwidth intensive applications up to 350MHz and beyond.
  • High-quality connectivity
    The Cat5e Non-Booted Unshielded (UTP) Network Patch Cable by C2G ensures a reliable connection with its gold-plated connectors and high-quality American Wire Gauge (AWG) 24 wiring. This combination provides a stable, high-speed link between devices.
  • Enhanced performance
    Designed to support frequencies up to 350 MHz, this patch cable facilitates high-speed data transmission and is ideal for a variety of networking applications. Its T568B wiring scheme and UTP technology help in reducing noise and crosstalk, enhancing your network's performance.
  • Durable design
    Featuring a PVC jacket, the cable is built to withstand rigorous or everyday use, ensuring longevity and durability. The robust construction also includes a male RJ-45 connector on each end, making it easy to connect devices.
  • Universal compatibility
    This network patch cable is compatible with PCs and supports a wide range of devices with an RJ-45 interface. Its universal design ensures it can be easily integrated into existing networks without compatibility issues.
C2G Cat5e Non-Booted Unshielded (UTP) Network Patch Cable - patch cable - 10 m - grey
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Stranded, uniboot
Length
10 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Stranded, uniboot
Length
10 m
Grey
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
