For voice/data/video distribution, this cable will handle bandwidth-intensive applications. Meets all Cat5E TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL).
Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
Constructed from high-quality cable and a shortened body plug, this design minimizes Near-End Crosstalk (NEXT) levels.
High-quality connectivity
The Cat5e Non-Booted Unshielded (UTP) Network Patch Cable by C2G ensures a reliable connection with its high-quality, 24 AWG American Wire Gauge (AWG) and gold-plated connectors. Designed for durability and long-lasting performance, this cable supports the T568B wiring scheme. -
Enhanced performance
Experience enhanced network performance with the Cat5e cable, tested for frequencies up to 350 MHz. This ensures high-speed data transmission for applications such as video streaming, online gaming, and more, without any lag or interruption. -
Universal compatibility
Designed to meet the needs of a wide range of devices, this patch cable features male RJ-45 connectors on both ends, making it compatible with PCs and a variety of network equipment. Its compliance with RoHS standards further ensures broad compatibility and safe usage.
- C2G Cat5e Non-Booted Unshielded (UTP) Network Patch Cable - patch cable - 10 m - green
- Patch cable - CAT 5e
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Stranded, uniboot
- Length
- 10 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Green
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Stranded, uniboot
- Length
- 10 m
- Green
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 350 MHz
