This power cord is the ideal solution for powering a server or connecting to a PDU in a data center or network wiring closet. This cable is able to support up to 250 volt connections and features 14AWG condutor construction. The fully molded design provides for maximum durability and long life.
- C2G 14 AWG 250 Volt Power Cord - power cable - IEC 60320 C19 to IEC 60320 C14 - 3.05 m
- Power cable
- Molded
- Length
- 3.05 m
- Connector
- Power IEC 60320 C19
- Connector (Second End)
- Power IEC 60320 C14
- Rated Voltage
- AC 250 V
- Rated Current
- 15 A
- Black
- Limited lifetime warranty
- Power cable
- American Wire Gauge (AWG)
- 14
- Rated Voltage
- AC 250 V
- Rated Current
- 15 A
- Molded
- Length
- 3.05 m
- Black
- 499 g
- Connector
