C2G 100m Cat5e Non-Booted Shielded (STP) Network Patch Cable - Blue
Quicklinx: 9N3SWS00 Mfr#: 83780
Protect your high speed network from noise and electromagnetic interference when you connect with our shielded Cat5e patch cable. Constructed from high quality cable and plugs, this design minimises Near-End Crosstalk (NEXT) levels. The moulded boot provides extra strain relief and durability. Available in a variety of colours to easily colour-code your network installation.
  • Enhanced connectivity
    The Cat5e Booted Shielded (STP) Network Patch Cable by C2G ensures a reliable connection with its gold-plated RJ-45 connectors, providing superior signal quality and resistance to corrosion.
  • Robust design
    Featuring a durable PVC jacket and an American Wire Gauge (AWG) of 24, this patch cable is designed for longevity and optimal performance, minimizing Near-End Crosstalk (NEXT) for clearer signal transmission.
  • Versatile compatibility
    Designed to support a T568B wiring scheme and compatible with PCs, this network patch cable seamlessly integrates into various network configurations, ensuring a versatile solution for numerous applications.
C2G Cat5e Booted Shielded (STP) Network Patch Cable - patch cable - 100 m - blue
Patch cable - CAT 5e
Shielded twisted pair (STP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, minimised Near-End Crosstalk (NEXT)
Length
100 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
100 m
Blue
Connector
RJ-45 - male
RJ-45 - male
