C2G 100m Cat5e Booted Unshielded (UTP) Network Patch Cable – Grey
Quicklinx: 9N2PWS00 Mfr#: 83152
For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
  • Enhanced connectivity
    The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G ensures a reliable connection with its high-quality, gold-plated RJ-45 connectors. These connectors provide a secure link between devices, minimizing potential connectivity issues and ensuring stable network performance.
  • Durable design
    Constructed with a flame-retardant PVC jacket and featuring minimized Near-End Crosstalk (NEXT) and reduced structural return loss (SRL), this cable is designed for durability and long-term use. Its robust design helps maintain signal integrity, even in demanding environments.
  • Universal compatibility
    Designed to meet the TIA/EIA-568-B.2 standards and with a wiring scheme of T568B, this patch cable is compatible with a wide range of devices. Whether for home or office use, it seamlessly integrates with existing network setups, ensuring a hassle-free installation.
C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 100 m - grey
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded, minimised Near-End Crosstalk (NEXT), reduced structural return loss (SRL)
Length
100 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Wiring Scheme
T568B
Jacket Material
Flame retardant PVC (FR PVC)
American Wire Gauge (AWG)
24
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
100 m
Grey
Connector
RJ-45 - male
RJ-45 - male
RoHS, TIA/EIA-568-B.2
