C2G 1.8m USB IEEE-1284 Parallel Printer Adapter Cable
Quicklinx: 63TVWS00 Mfr#: 81626
Hurry, only 2 left in stock!
£15.39 ex VAT
£18.46 inc VAT
With C2G's USB to IEEE-1284 Printer Cable, you can use your USB port on your PC or hub and free-up the parallel port for a Zip drive or scanner. If you have multiple printers, you can eliminate the need for a switchbox by connecting each printer to a USB port. The device is fully transparent to the user, and is ideal for true bi-directional communication.
C2G USB to IEEE-1284 Printer Cable - parallel adapter
Parallel adapter
External
Interface (Bus) Type
USB
Ports
IEEE 1284
Parallel
Beige
Microsoft Windows 98/ME/2000/XP, Microsoft Windows Vista
1-year warranty
Parallel adapter
External
USB
Ports
IEEE 1284
Wired
Parallel
1 x IEEE 1284 (EPP/ECP) - 36 PIN Centronics
1 x USB - 4 pin USB Type A
1 x USB cable (integrated) - 1.8 m
Beige
Limited warranty - 1 year
Brand: C2G
Price Range Ex VAT: 0 - 50
