Connecting USB with the traditional RS-232 serial port, this adapter connects mobile phones, PDAs, digital cameras, modems, or ISDN terminal adapters through your USB port . This Adapter Cable has a data transfer rate of over 250 kbps. Since the adapter uses no IRQs, there are no IRQ conflicts, and it is ideal for when you need many serial devices attached to your PC. Use this adapter to connect directly to a serial device or to free your RS-232 port for other uses.
[] Download the driver from the Support tab (if applicable).
[] Download a PDF with the technical specifications of this product on the Support tab or view the technical specifications of this product on the Specs tab Note: Using this adapter with a Chromebook requires a serial terminal application. This type of application may be downloaded from the Chrome Web Store.
Enhanced durability
The Serial RS232 Adapter Cable is encased in a robust PVC jacket, ensuring it remains protected against wear and tear for reliable, long-term use. -
High-quality connectivity
Featuring gold-plated connectors and double-shielded with aluminum and mylar, plus a tinned copper braid, this cable ensures a secure and interference-free connection. -
Versatile compatibility
Designed to connect seamlessly with PC systems, this adapter supports a wide range of applications, making it a versatile addition to your connectivity solutions.
- C2G Serial RS232 Adapter Cable - USB / serial cable - USB to DB-9 - 1.5 m
- Technology
- Double shielded
- Length
- 1.5 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 9 pin D-Sub (DB-9) - male
- USB / USB 2.0
- Black
- 1-year warranty
- Technology
- Double shielded
- Shielding Material
- Aluminium and mylar with tinned copper braid
- Jacket Material
- PVC
- Plated Connector
- Gold
- Length
- 1.5 m
- Black
- 118 g
- Connector
- USB / USB 2.0
- 1-year warranty
