Experience ULTRA HD (4K) displays with this Select High-Speed HDMI Cable which provides a fast and reliable connection for home theatre or desktop audio video applications requiring high speed HDMI capabilities and video resolutions up to 4K (2160p). This High-Speed HDMI Cable supports the latest HDMI features including Ultra HD, 4K at 50/60 (2160p), up to 32 audio channels and wide angle theatrical 21:9 video aspect ratio and is compatible with any modern Laptop, Chromebook, HDTV or gaming console, including Sony PlayStation 4 (PS4) and Microsoft Xbox ONE. The cable is also backwards compatible with PlayStation 3 (PS3) and Xbox 360. The CL2 rated cable jacket is designed to meet the requirements for in-wall installations. The Ethernet capabilities of the cable allow users to connect multiple Ethernet-enabled HDMI devices through a single Ethernet connection. This fully-functional, high bandwidth cable is tested to perform at industry standards and is backed by a lifetime warranty. Note: Both the source device and display must support a HDMI feature in order to pass that particular feature through this cable.
 - C2G 1.5m Select High Speed HDMI Cable with Ethernet - 4K - UltraHD - HDMI cable with Ethernet - 1.5 m
- Cable
- Technology
 - Shielded
- American Wire Gauge (AWG)
 - 28
- Length
 - 1.5 m
 - Black
- Connector
 - HDMI - male
- Connector (Second End)
 - HDMI - male
 - Limited lifetime warranty
- Cable Type
- Technology
 - Shielded
 - 28
- Jacket Material
 - PVC
- Shielding Material
 - Aluminium foil with braid
- Impedance
 - 100 Ohm
- Length
 - 1.5 m
- Plated Connector
 - Gold
 - Black
- Connector
 - 19 pin HDMI Type A - male
 - UL
 - Limited warranty - lifetime
