The Select High Speed HDMI Cable with Ethernet is the perfect solution for connecting multimedia source devices in home theatre, desktop or commercial audio video applications requiring high speed HDMI features. The CL2 rated cable jacket is designed to meet the requirements for in-wall installations. The Ethernet capabilities of the cable allow a user to connect multiple Ethernet enabled HDMI devices through a single Ethernet connection. Note: Both the source device and display must support a HDMI feature in order to pass that feature through this cable Connector 1: (1) HDMI Male Connector 2: (1) HDMI Male.
High-quality connectivity
The 1.5m High Speed HDMI Cable with Ethernet from C2G is designed with gold-plated conductors, ensuring a high-quality connection that delivers an excellent audio and video experience. -
Durable design
Featuring a PVC jacket and aluminum foil with braid shielding, this HDMI cable is built for durability and long-lasting performance, reducing the risk of damage from regular use. -
Versatile compatibility
With support for 4k and UltraHD resolutions, this cable is perfect for a wide range of devices and setups, from gaming consoles to home theater systems, ensuring your entertainment setup is well-prepared for the future.
- C2G 1.5m High Speed HDMI Cable with Ethernet - 4k - UltraHD - HDMI cable with Ethernet - 1.5 m
- Cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 30
- Length
- 1.5 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - male
- Gold-plated conductors
- Limited lifetime warranty
- Cable Type
- Technology
- Shielded
- 30
- Jacket Material
- PVC
- Shielding Material
- Aluminium foil with braid
- Length
- 1.5 m
- Black
- Connector
- 19 pin HDMI Type A - male
- RoHS
- Limited warranty - lifetime
