C2G 1.5m High Speed HDMI with Ethernet Cable
CLEARANCE!
Clearance
Price Drop
Quicklinx: 915YWS00 Mfr#: 82025
Type: HDMI
Length: 1.5m
Select:
£5.22 ex VAT
£6.26 inc VAT
The Select High Speed HDMI Cable with Ethernet is the perfect solution for connecting multimedia source devices in home theatre, desktop or commercial audio video applications requiring high speed HDMI features. The CL2 rated cable jacket is designed to meet the requirements for in-wall installations. The Ethernet capabilities of the cable allow a user to connect multiple Ethernet enabled HDMI devices through a single Ethernet connection. Note: Both the source device and display must support a HDMI feature in order to pass that feature through this cable Connector 1: (1) HDMI Male Connector 2: (1) HDMI Male.
  • High-quality connectivity
    The 1.5m High Speed HDMI Cable with Ethernet from C2G is designed with gold-plated conductors, ensuring a high-quality connection that delivers an excellent audio and video experience.
  • Durable design
    Featuring a PVC jacket and aluminum foil with braid shielding, this HDMI cable is built for durability and long-lasting performance, reducing the risk of damage from regular use.
  • Versatile compatibility
    With support for 4k and UltraHD resolutions, this cable is perfect for a wide range of devices and setups, from gaming consoles to home theater systems, ensuring your entertainment setup is well-prepared for the future.
C2G 1.5m High Speed HDMI Cable with Ethernet - 4k - UltraHD - HDMI cable with Ethernet - 1.5 m
Cable
Shielded
American Wire Gauge (AWG)
30
Length
1.5 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
Gold-plated conductors
Cable Type
Shielded
30
Jacket Material
PVC
Shielding Material
Aluminium foil with braid
Length
1.5 m
Connector
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
Type: HDMI
Length: 1.5m
Brand: C2G
