C2G 1.5m Cat6 UTP LSZH Network Patch Cable - Green
Quicklinx: CMHQWS00 Mfr#: 82467
For fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels with a LSZH outer jacket. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily colour-code your network installation. Each cable is individually labelled with the length for ease of use.
Connector 1: (1) RJ-45 Male.
Connector 2: (1) RJ-45 Male.
  • Enhanced connectivity
    Featuring gold-plated RJ-45 connectors on both ends, this CAT 6 patch cable ensures a secure and corrosion-resistant connection, enhancing signal integrity and network performance.
  • Robust design
    The cable is designed with a Low Smoke Zero Halogen (LSZH) jacket, minimizing the risk of toxic smoke emission in case of fire, making it a safer choice for enclosed spaces.
  • High performance
    Equipped with features like minimized Near-End Crosstalk (NEXT) and reduced structural return loss (SRL), this cable improves signal quality and provides a reliable network connection.
  • Easy handling
    Booted and snagless design with a latching clip makes handling and installation of the cable hassle-free, preventing cable snags and ensuring a secure lock in place.
C2G patch cable - 1.5 m - green
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wires per Cable
8 wires
Booted, snagless, minimised Near-End Crosstalk (NEXT), reduced structural return loss (SRL), latching clip
Length
1.5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Green
Network Cable Type
Patch cable - CAT 6
Jacket Material
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
1.5 m
65 g
Green
Connector
RJ-45 - male
RJ-45 - male
RoHS, TIA/EIA-568-B.2
