For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
High-speed connectivity
Experience seamless network performance with the Cat6 Booted Unshielded (UTP) Network Patch Cable, designed to support frequencies up to 550 MHz. This ensures high-speed data transfer for server applications, cloud computing, and HD video streaming. -
Durable design
Constructed with a PVC jacket and 24 AWG copper wires, this patch cable is built for durability and reliable connectivity. The gold-plated RJ-45 connectors provide optimal signal clarity and shielding against interference, ensuring a stable connection in various environments. -
Universal compatibility
Featuring a T568B wiring scheme and compatible with PC systems, this network patch cable offers broad compatibility. It's designed to connect seamlessly with a wide range of devices, facilitating easy integration into existing networks.
- C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 1.5 m - pink
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Molded, snagless, stranded
- Length
- 1.5 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Pink
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Plated Connector
- Gold
- Length
- 1.5 m
- Pink
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 550 MHz
