C2G 1.5m Cat6 550 MHz Snagless Patch Cable - Grey
Quicklinx: 6BPGWS00 Mfr#: 83367
Length: 1.5m
Colour: Grey
£3.38 ex VAT
£4.05 inc VAT
For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
  • High-quality connectivity
    The Cat6 Booted Unshielded (UTP) Network Patch Cable by C2G is designed with a PVC jacket and gold-plated connectors, ensuring durable and reliable connectivity for all networking needs.
  • Enhanced performance
    With a tested frequency of up to 550 MHz and adhering to the T568B wiring scheme, this patch cable is built to facilitate high-speed data transmission and minimize crosstalk, making it ideal for various networking environments.
  • Universal compatibility
    Featuring RJ-45 male connectors on both ends, this network patch cable is compatible with a wide range of devices, ensuring a seamless connection for PCs and other network components.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 1.5 m - grey
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
1.5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Plated Connector
Gold
Length
1.5 m
Grey
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
Length: 1.5m
Colour: Grey
Brand: C2G
