For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
High-speed connectivity
Experience seamless network performance with the Cat6 Booted Unshielded (UTP) Network Patch Cable, designed to support tested frequencies up to 550 MHz. This ensures optimal performance for your networking needs, making it an ideal solution for high-speed Internet, file transfers, and video streaming. -
Durable design
Constructed with a PVC jacket and 24 AWG wire, this patch cable is built for durability and long-term use. The gold-plated RJ-45 connectors provide a reliable connection and resist corrosion, ensuring your network setup remains intact and performs well over time. -
Universal compatibility
Designed to meet the T568B wiring scheme and RoHS compliant standards, this network patch cable is compatible with a wide range of devices and networks. Whether you're connecting PCs or extending your network, this cable offers the flexibility and reliability you need.
- C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 1.5 m - blue
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Molded, snagless, stranded
- Length
- 1.5 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Blue
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Plated Connector
- Gold
- Length
- 1.5 m
- Blue
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 550 MHz
