Cables To Go's Cat6 crossover cables are perfect for distributing data, voice, video and connecting network switches and hubs without an uplink port to other switches and hubs. These 550MHz rated patch cables ensure that you always have the necessary throughput to handle bandwidth-intensive applications. Note:These cables are for 10/100 ethernet only and will not work for gigabit ethernet as only two pairs of this cable are crossed.
Enhanced connectivity
The Cat6 Booted Unshielded (UTP) Crossover Patch Cable by C2G is designed to connect and transfer data between PCs efficiently. Its gold-plated RJ-45 connectors ensure a secure and corrosion-resistant connection, enhancing the longevity and reliability of your network. -
High-speed performance
With a tested frequency of up to 550 MHz, this crossover cable is built for high-speed data transmission. The American Wire Gauge (AWG) of 24 along with the Category 6 specification supports bandwidth-intensive applications without compromising on speed or quality. -
Durable design
Crafted with a PVC jacket material, the cable offers a durable and flexible solution for your networking needs. Its robust construction ensures it can withstand various environmental conditions, making it suitable for both indoor and outdoor use.
- C2G Cat6 Booted Unshielded (UTP) Crossover Patch Cable - crossover cable - 1.5 m - red
- Crossover cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Molded, snagless, stranded
- Length
- 1.5 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Red
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Plated Connector
- Gold
- Length
- 1.5 m
- Red
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 550 MHz
